CD 4510be operation
Arjune
Joined Jan 6, 2018
354
According to the data it says that you have to keep the clock high before you switch count Up or down on the cd4510be counter.
What if S1 is on, serving as a brake, can I then change up or down direction and that would be okay?
38,802
Yes, but you need a 10kΩ resistor from pin 15 to ground to insure that the signal goes low at that pin when the clock goes low (since the diode prevents it from being pulled low).
Note that diode on the switch is redundant.
What is the clock frequency?
Arjune
Joined Jan 6, 2018
354
Yes, but you need a 10kΩ resistor from pin 15 to ground to insure that the signal goes low at that pin when the clock goes low.
The clock frequency would be 1 Hertz and also 100 Hertz approximately. I thought one Meg would be okay from pin 15 to ground
Arjune
Joined Jan 6, 2018
354
I'm not sure about this scenario. What if I change the up/down with s1 off, then I turn s1 on, would I restore the counter to proper operation by switching s1 again or do I have to power off then power on again?
eetech00
Joined Jun 8, 2013
4,724
hi
good thinking!
standard practice for digital circuits is to initialize the devices to the required state before normal operation. Generally done with a power on reset (POR) circuit. That ensures the 4510 will begin at count 0 after power is applied.
eT
38,802
The counter will still change the up/down direction but it may miss counts in the process.
You shouldn't have to power it off and back on.
