Yep, show us more of this circuit.Welcome to AAC.
Difficult to say without seeing the whole circuit.
One reason could be for protection.
The Voltage drop is indeed the Vf of the diode.
Precision rectifier was my first thought but (one of) the diode polarities is wrong for that.The circuit appears to be a negative peak detector.
From a few google searches it definately does look like that (or a modified version). Thank you very much.The circuit appears to be a negative peak detector.
Yes, from the C6 polarity it would appear that D8 should be reversed so it would be a positive peak detector.Precision rectifier was my first thought but (one of) the diode polarities is wrong for that.
I'll double check a board to make sure the drawings match the actual components on the board.Yes, from the C6 polarity it would appear that D8 should be reversed so it would be a positive peak detector.
It's that backwards D8 that keeps throwing me for a loop. I think I need to run back through basic electronics. It's hard to google information about circuits when you don't even know their name.
