Case Cade amplifier
BobTPH
Joined Jun 5, 2013
11,664
The TS’s original plot is output voltage vs pressure. How is LTSPICE supposed to duplicate that plot?
ericgibbs
Joined Jan 29, 2010
21,602
Hi Bob,
If I understand your query correctly, as resistor Rm represents the resistance of the Sensor, it would be possible, using LTSpice, to inject a series voltage, proportional to the pressure in that Rm path.
I hope the TS comes back with more information so that we can post are meaningful response.
E
Tanveerh165
Joined Apr 12, 2021
7
Hi Alex,
Why did you post #17 with a circuit did not produce the plot?
This plot is also different from your post #19 plot.
I am trying to determine the cause of the problem .
E
ericgibbs
Bordodynov
eetech00
BobTPH
Thanks all of you for your reply, i was off work on Friday evening, now i am back to work again. before i also try simulation on Proteus, but simulation results are totally different from my real circuit results. i am trying to figure out the root cause. if you have any further suggestion share with me, i will try, if i could make it successfully i will share results with you. thanks again
BobTPH
Joined Jun 5, 2013
11,664
Perhaps the real circuit and simulated circuit are not the same. I would recheck all the wiring and values of components in the real circuit.
