Cascode Stage Biasing
demir-ali
Joined Jul 13, 2024
324
Hello , Im having trouble with biasing these mosfets. Actually I am trying to make an amplifier that is at least near to be rail to rail.
Now I wonder , how should I bias those M4 , M3 , M2.
If you can share an working example , I be really happy.
demir-ali
Joined Jul 13, 2024
324
Actually it is not into a project. Im just practicing to have better viewpoint.
I may use telescopic cascode on diffamp to make it rail to rail.
demir-ali
Joined Jul 13, 2024
324
I'am very similar with small signal models and gains of these topologies but biasing is a complete different world.
demir-ali
Joined Jul 13, 2024
324
To give instance , how could I improve this differantial amplifier in gain and bw. At output I would use class ab.1735862242445.png
LowQCab
Joined Nov 6, 2012
5,102
It depends on who You ask, and specifically, what exact Specifications You expect it to achieve,
as in, how-high-is-up, and how much Money do You have ?
28,307
If you are able to bias each device with resistors from that devices Drain and Source, it could work. Maybe..
I suggest reviewing the biasing schemes used for cascode tube amplifiers many years ago. It was some brilliant development work done in the 1950 to 1965 era.
demir-ali
Joined Jul 13, 2024
324
Could you give some references and May be examples plase?
28,307
Unfortunately much of the vacuum tube presentations were in articles I read at the time, in publications that were often shared with others, prior to 1970. They may be archived someplace. I do not have access to any of that now.
demir-ali
Joined Jul 13, 2024
324
Then first learn them.
Cascode stages, (your sim has a current-mirror load and is not a cascode), are something you use for a different purpose.
I know. I have studied. Desigining an amplifier is not such a basic task. I be happy I can find some examples.
LowQCab
Joined Nov 6, 2012
5,102
I gave You a generic example Schematic in Post#5.
It's not tested, but it should work just fine with careful selection of the High-Current/High-Voltage Op-Amps.
As a ~250-Watt-Audio-Amp, it will generate a substantial amount of Heat,
so the Output FETs may need to be doubled or even tripled to dissipate the Heat.
28,307
The audio amplifier in the circuit does not come close to my understanding of a cascode circuit . Not even slightly similar to any of them that I have seen. They were, all small signal RF amplifiers. Only one input, only one output. A series power amplifier is rather vastly different. Your circuit is intended to increase the power output by extending the voltage swing, which is very reasonable but totally different.
Bordodynov
Joined May 20, 2015
3,431
It is a bad idea to connect two current sources in series. The cascade is a good current source. You can achieve that the output level in the simulation is equal to half of the power supply by making the parameters of the p- and n-channel transistor models the same at Vn =-Vp, but in reality you will not achieve this. Negative feedback should be used. As an intermediate internal stage, you can use your combination of four transistors, i.e. as part of a larger circuit. You don't use an operational amplifier without direct current negative feedback. The situation is similar here. Your cascade has a high gain.
28,307
Now a question: Since designs for working audio amplifiers at all sorts of power levels are freely available, at up to over 1000 watts, WHY consider using stacked transistors when proven and available designs are around?? High gain in a power output stage is seldom used, because it is very tricky to keep linear and stable.
So what is the motivation for the proposed stacked devices????
