Cascaded Op Amp circuit
Status
Not open for further replies.
arthur442
Joined Jul 10, 2021
18
Arthur - as I have mentioned in my post, all these solutions are not correct.
You are not allowed to use the condition (Va=Vb and V2=V3)
So what is the correct method to solve this? Because in post #8 Jony writes that I have to do this.
LvW
Joined Jun 13, 2013
2,036
hi 442,
Your calculations in post #19 look OK to me.
E
Eric, sorry to say - however, how can this solution be correct?
Look here:
Va=-2V (pos. input opamp).
Gain G=+3
V01= + 6V .
Question: How can the output be positive when the input is negative and the gain positive?
A typical result for an amplifier that is useless because it has no DC bias point in the linear range.
LvW
Joined Jun 13, 2013
2,036
Arthur, there is no solution which makes sense!! Do you know what it means to say that an amplifier is unstable due to positive DC feedback? It is in saturation!
Recommedation: Ask Jony for a comment.
arthur442
Joined Jul 10, 2021
18
Ok, I did some quick research on saturation. What I understand from it (and correct me if I'm wrong) is because the op amp has a minimum range of 0V because it is connected to ground. As a result, it cannot reach the -6V on V01.
Is this good ?
Status
