Hi everybody, I'm new to the site and to electronics, but I'm trying very hard to learn. I have a classic Alfa Romeo and I'd like to remove the distributor points and replace them with a solid state solution. I'd like to use this opportunity to learn something better about electronics and it's a fun and, I think, fairly simple project. I would really love some help if someone can review what I have and tell me where I've headed for the rocks.
The general idea is to replace the points with a Hall Effect cam position sensor that can read the cam lobes on the existing distributor shaft that drive the points and generate a signal to fire the ignition coil. The coil itself will be controlled by a Bosch ignition module for which I simply must provide the ground at the time it should fire the coil.
So as far as I can tell if I use the Hall Effect Sensor, some components to protect it from the automotive environment, and a good high voltage, high current transistor, I pretty much have my circuit? But I'm not as sure about the details and I'm worrying that I'm missing something crucial that it will result in frying something.
My plans are to use this Hall Effect cam position sensor which looks like it does exactly what I want and it can handle automotive temperatures and stresses:
http://melexis-microcontrollers.com/Asset.aspx?nID=4759
I will want to upgrade this system to use a higher voltage capacitor discharge ignition setup eventually so I picked a fast switching high voltage, high current transistor that looks like it fits the job well:
http://www.fairchildsemi.com/ds/FJ/FJD5304D.pdf
What I can't tell very well from the spec sheets, because I don't know what I'm doing, is if the output from the Hall Effect sensor will be high enough to trigger the transistor. Do I need another transistor with a lower base trigger level to in turn operate the FJD5304?
Info in the Bosch ignition module is about half way down here:
http://megasquirt.sourceforge.net/extra/setup-msns.html
So I was going to implement the recommended automotive circuit from the MLX90217 sheet like in the attachment, with the collector from the transistor going to the Bosch unit pin 6 and the emitter to ground.
Does that make sense? Am I missing something.
Help is very much appreciated.
Cheers,
Karl
Cheers,
Karl
