Car charger for dc powered pico projector question
DeeGore
Joined Sep 10, 2010
8
Hi, I have an aaxa p6 pico projector. It has a power supply that takes 120v and outputs 19v 2000ma dc.
Instead of using an inverter to power it from my car, can i use a laptop charger with the same output?
https://www.ebay.com/itm/Car-Charge...7YAAOSwSgJXOMSD:sc:USPSFirstClass!55804!US!-1
This one looks like it will work, but I wanted to ask in case there is a reason this might break my projector.
I might have to cut and solder the plug, but I don't see that bring a problem.
dl324
Joined Mar 30, 2015
18,523
The only thing I'd worry about is if the projector ever actually needed 2A and, if it did, whether the inverter you're thinking about could actually provide it.
