Look better nowTry this new firmware.
Not yet best ? Make small .3gp video and post it here for me to understand the exact problem.
Edit:
My guess was right. Sorry, my mistake. WDT was enabled and it was not cleared in the code. I have added WDT clearing code. Now it will work fine.
Test it and make small video and post it here.
Breadboard connection for adc input might be the problem. Solder adc connections and test.
There is at you tube 1.03mb, aac has no video upload,the firm ware is better
Thank you, and all connection need to solderBreadboard connection for adc input might be the problem. Solder adc connections and test.
My previous post is updated. Check it.Thank you, and all connection need to solder
Check my previous 2 posts.
5V 350 mA is enough for PIC and display.I dont have a diagram, its my old device i buy,about 500 ma 5 v, then i need 600 ma and above?
Try this firmware. It it still fluctuates then change your 5V power supply or add a 1000 uF 16V and 100 nF 16V in parallel to 5V power out.
Firm ware g,
Yes, I think that is enough. 1.5 sec delay is used. I will send you one more .hex file for testing after a few minutes. Did you add Capacitors I mentioned to the 5V power supply out ?
Going slow down, its ok
Not yet for capasitor, ok for hex file,thank youYes, I think that is enough. 1.5 sec delay is used. I will send you one more .hex file for testing after a few minutes. Did you add Capacitors I mentioned to the 5V power supply out ?
You can power the circuit from 12V battery itself using a LM7805 regulator,.The capasitor power supply 5 v is weak, and i will change soon
