Thank youI will make a new code for you.
Here I have posted Common Anode Code. If you don't have a compiler then I can make a code for you tomorrow.
https://forum.allaboutcircuits.com/...g-adc-value-on-four-7-segment-display.138974/
Do you want code for PIC16F877A ? Do you have a circuit ? If not, then can I design the circuit ? What is the max battery voltage ?Thank you
Yes i want, i use pic16f877a for 4 digit seven segment anode cathode,max battery is 14.6 vdc, i have dont wire test my cirquitDo you want code for PIC16F877A ? Do you have a circuit ? If not, then can I design the circuit ? What is the max battery voltage ?
Draw the circuit using Proteus if you have or draw it on paper and scan it and post the circuit.I have done wire my cirquit
Just provide circuit in whatever format you can or mention the connections.I dont no use protius
This image will not help me.That resistor at seven segman display, i not put it, i have it
You want to retain the same pin connections for PIC16F877A ?This is hex file for pic 16f1827 at cirquit
by Jake Hertz
by Duane Benson
by Duane Benson
by Duane Benson
