Check if the attached circuit is ok.Oh, yes, have at my country, what is work for,
Yes 2x 22pf 16V. Multilayer Ceramic type will be better.Then, need capasitor too for my cirquit,for running cristal
Thank youYes 2x 22pf 16V. Multilayer Ceramic type will be better.
Ok.Yes, i can follow
In my circuit can you replace R3 with 2.2k ?
Because of this low adc voltage.I dont no, y?
Find the attached .hex file.
#include "float2ascii.h"
#define Ascii_Base 0x30
#define Dp 0x80;
#define Blank 0xFF
#define SSD_DATA_PORT PORTB
#define SSD_CTRL_PORT PORTA
//#define Max_Volt_To_Measure 15.698924
#define Max_Volt_To_Measure 14.6
#define Adc_Resolution 1023
char str_Volt[32];
unsigned int raw_adc_value = 0, previous_raw_adc_value = 1023;
double volt = 0.0;
unsigned char digits[4] = {0, 0, 0, 0};
unsigned char digit = 0;
unsigned char cc_mask[10] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F};
unsigned char my_flags = 0;
sbit run_once_flag at my_flags.B0;
//Timer1
//Prescaler 1:1; TMR1 Preload = 64536; Actual Interrupt Time : 1 ms
void InitTimer1() {
T1CON = 0x01;
TMR1IF_bit = 0;
TMR1H = 0xFC;
TMR1L = 0x18;
TMR1IE_bit = 1;
void Interrupt() {
if((TMR1IE_bit) && (TMR1IF_bit)) {
//Enter your code here
SSD_CTRL_PORT &= 0xD1;
switch(digit) {
case 0:
SSD_DATA_PORT = digits[0];
SSD_CTRL_PORT = (SSD_CTRL_PORT & 0xD1) | 0x02;
break;
case 1:
SSD_DATA_PORT = digits[1];
SSD_CTRL_PORT = (SSD_CTRL_PORT & 0xD1) | 0x04;
break;
case 2:
SSD_DATA_PORT = digits[2];
SSD_CTRL_PORT = (SSD_CTRL_PORT & 0xD1) | 0x08;
break;
case 3:
SSD_DATA_PORT = digits[3];
SSD_CTRL_PORT = (SSD_CTRL_PORT & 0xD1) | 0x20;
break;
if(++digit >= 4) {
digit = 0;
TMR1IF_bit = 0;
TMR1H = 0xFC;
TMR1L = 0x18;
void main(void) {
CMCON = 0x07;
ADCON0 = 0x40;
ADCON1 = 0xCE;
TRISA = 0x01;
TRISB = 0x00;
TRISC = 0x00;
TRISD = 0x00;
TRISE = 0x00;
PORTA = 0x00;
PORTB = 0x00;
PORTC = 0x00;
PORTD = 0x00;
PORTE = 0x00;
Delay_ms(200);
InitTimer1();
while (1) {
raw_adc_value = ADC_Read(4);
Delay_us(20);
if(previous_raw_adc_value != raw_adc_value) {
volt = (((double)raw_adc_value * Max_Volt_To_Measure) / Adc_Resolution);
Float2Ascii(volt, str_Volt, 3);
if((volt >= 1.0) && (volt < 10.0)) {
digits[0] = cc_mask[str_Volt[0] - Ascii_Base] | Dp;
digits[1] = cc_mask[str_Volt[2] - Ascii_Base];
digits[2] = cc_mask[str_Volt[3] - Ascii_Base];
digits[3] = cc_mask[str_Volt[4] - Ascii_Base];
else if((volt >= 10.0) && (volt < 100.0)) {
digits[0] = cc_mask[str_Volt[0] - Ascii_Base];
digits[1] = cc_mask[str_Volt[1] - Ascii_Base] | Dp;
if(run_once_flag == 0) {
INTCON = 0xC0;
run_once_flag = 1;
previous_raw_adc_value = raw_adc_value;
if((volt >= 0.0) && (volt < 10.0)) {
#define Dp 0x80;
#define Max_Volt_To_Measure 15.6989247
char str_Volt[32];
double volt = 0.0;
unsigned char digit = 0, shift_value = 0x02;
//Timer1
void InitTimer1() {
T1CON = 0x01;
TMR1IF_bit = 0;
TMR1H = 0xFC;
TMR1L = 0x18;
TMR1IE_bit = 1;
void Interrupt() {
SSD_DATA_PORT = digits[digit];
SSD_CTRL_PORT = (SSD_CTRL_PORT & 0xD1) | shift_value;
shift_value <<= 1;
if(shift_value == 0x10)shift_value <<= 1;
if(shift_value == 0x40)shift_value = 0x02;
if(++digit >= 4) {
digit = 0;
TMR1IF_bit = 0;
TMR1H = 0xFC;
TMR1L = 0x18;
void main(void) {
CMCON = 0x07;
TRISA = 0x01;
TRISB = 0x00;
TRISC = 0x00;
TRISD = 0x00;
TRISE = 0x00;
ADCON0 = 0x40;
ADCON1 = 0xCE;
PORTA = 0x00;
PORTB = 0x00;
PORTC = 0x00;
PORTD = 0x00;
PORTE = 0x00;
Delay_ms(200);
InitTimer1();
while (1) {
raw_adc_value = ADC_Read(0);
Delay_us(20);
else if((volt >= 10.0) && (volt <= 16.0)) {
if((volt >= 0.0) && (volt <= 16.0)) {
INTCON = 0xC0;
run_once_flag = 1;
Reduced the RAM usage.Thank you i will studied
#define Dp 0x80;
#define Adc_Resolution 1023.0
double volt = 0.0;
unsigned int tmp = 0;
char ten = 10;
//Timer1
void InitTimer1() {
T1CON = 0x01;
TMR1IF_bit = 0;
TMR1H = 0xFC;
TMR1L = 0x18;
TMR1IE_bit = 1;
void Interrupt() {
shift_value <<= 1;
if(++digit >= 4) {
digit = 0;
TMR1IF_bit = 0;
TMR1H = 0xFC;
TMR1L = 0x18;
void main(void) {
CMCON = 0x07;
TRISA = 0x01;
TRISB = 0x00;
TRISC = 0x00;
TRISD = 0x00;
TRISE = 0x00;
ADCON0 = 0x40;
ADCON1 = 0xCE;
PORTA = 0x00;
PORTB = 0x00;
PORTC = 0x00;
PORTD = 0x00;
PORTE = 0x00;
Delay_ms(200);
InitTimer1();
while (1) {
Delay_us(20);
tmp = (unsigned int)(volt * 1000.0);
digits[3] = cc_mask[tmp % ten]; tmp /= ten;
digits[2] = cc_mask[tmp % ten]; tmp /= ten;
digits[1] = cc_mask[tmp % ten]; tmp /= ten;
digits[0] = cc_mask[tmp % ten] | Dp;
tmp = (unsigned int)(volt * 100.0);
digits[1] = cc_mask[tmp % ten] | Dp; tmp /= ten;
digits[0] = cc_mask[tmp % ten];
INTCON |= 0xC0;
run_once_flag = 1;
Which programmer are you using ? Genuine or clone ?I just to program my pic, and, its say receive data error, and i try previous code, from first time pic16f1827 just OK, wonder
I have mikroProg for PIC Program,mer/Debugger and I never had problems with it.DIY k150 v150807,i don't know genuine or clone, may about my pic kit
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Jake Hertz
