Capacitor value for RS-232 Driver Circuit
MTech1
Joined Feb 15, 2023
181
I am working on developing a driver circuit to send data from my PIC microcontroller to a PC using RS-232. While reviewing the datasheet for the MAX232 IC, I noticed that certain capacitors are required.
I have a ceramic capacitors with "104" written on it, and I believe its capacitance value is 0.1 µF (not 1 µF). Could you please confirm if my understanding is correct? Also, if I need a 1 µF capacitor, should I look for one marked as "105"?
35,180
That is correct.
104 = 10 x 10000 = 100000 pF = 100 nF = 0.1 μF
105 = 10 x 100000 = 1000000 pf = 1000 nF = 1 μF
Note that different RS-232 converter ICs require different value charge capacitors. Go with the manufacturer's recommendations.
John P
Joined Oct 14, 2008
2,068
The MAX233 does the same job without external capacitors, but if the MAX232 is what you've got, you'll have to install them. But RS-232, really, in this day and age? It's a hangover from medieval times.
