Capacitor in a power supply
Rufinus
Joined Apr 29, 2020
323
Hello. For ZVS induction heater I need a 35V 10 or 15 amps power supply. At home I have 223 VAC and 50hz.
My idea is to remove the seocondary of a microwave transformer and rewound it with a thicker wire. What voltage should I get in that secondary to get the 35V after rectifying and filtering? I´ll use a fuuuuuull bridge rectifyer anf after a feew capacitors in parallel to filter. That is my second question, the value of the voltage and capacitance. I have thought in 63V (they are very common and not very exopensive) but no clue about the value of the capacitance. Any suggestion?
Thank you
Best regards
Rufinus
Joined Apr 29, 2020
323
Thabk you
Oh, I thought that the capacitance it has to be not only with the voltage but also with the current.
Ant if I get 35 VDC the value of the voltage has to be smaller? I thought it has to be bigger
Papabravo
Joined Feb 24, 2006
22,111
Capacitors do not pass DC current only AC current. In the case of polarized capacitors, you have to be careful you don't reverse the polarity on them. If you do the magic smoke will exit the package, usually with some level of violence. I have seen jets of steam rise 20 feet into the rafters.
MaxHeadRoom
Joined Jul 18, 2013
30,791
If the TXMR has a magnetic shunt, you should remove/punch that out, preferably.
You need to wind on a small over-wind of ~10 turns to determine the turns/volt of the new secondary.
Rufinus
Joined Apr 29, 2020
323
Thank you. yes I did something similar to make a spot welder. Very thick wire ant only 1,5 turns. But I´m not sure about the value of the capacitors for 35VDC and 10-15 amps
Hello!
It's an easy calculation:
Q = C * dU = I * dt
dt is about 10ms (full bridge rectifier)
And you have to take care the ripple current specification of the selected capacitance, for this current you may have to use some parallel capacitance to provide enough ripple current.
Gabor
Pyrex
Joined Feb 16, 2022
539
A practical formula to calculate filter capacitor value if bridge is used and mains frequency is 50KHz:
C= ( I*0.01 )/dU
Where I means load current in amps, dU means ripple voltage in volts. General purpose electrolytic capacitors do not tolerate high ripple, so usually dU = 0.1 * U , or less.
Required transformer voltage is about 30VAC at no load.
Voltage drop at diodes is about 2V. 30-2=28V. Due to capacitor voltage rises up to the peak voltage 28*1.41= 39.5V. Voltage drop due to winding resistance is about 10% , so 39.5/1.1= 35.9V
28,141
Induction heater systems are rather tolerant of ripple, it mostly affects the actual power. But there is a lot of current into and out of the capacitor, so physically larger capacitors make sense.
Rufinus
Joined Apr 29, 2020
323
Thank you. And what special with wima MKP capacitors? I have KEMET MKP X2 SH. These ones are not suitsable for the oscillator?
