I have recently completed a PCB board to control the PWM fan on a Mercedes radiator fan. The board works very well and I have no issues in the current application. However several people on the Arduino forums have pointed out that my filtering caps are not connected correctly. I have also tested the board without caps and it works just as good without them. So I really cant tell if the caps are doing there job correctly or not. I will be building a new board to integrate a time delay shut off circuit so I will have the opportunity to correct this if it needs to be corrected. The caps that are in question are C1, C2, C3. I'm not sure if I used the correct symbols for those caps, but they are regular ceramic non-polarized 0.1uf caps. Not shown in the schematic are three thermisters connected across pins 11-12, 13-14, 15-16.
Your thoughts would be appreciated.
