Capacitor calculations
HarrisonG
Joined Aug 1, 2016
73
Hi. I tried to calculate the time constant on this circuit that includes elements like diodes and transistors together with the capacitor and since about a week ago i found out that Time constant for a capacitor isnt simply C times the resistor it charges/discharges through(unless the circuit is R and C in series), i have had a little trouble calculating it in circuits like the above one. Did i calculated this one right?
ColinPatra
Joined Jan 27, 2018
28
The time constant is RC. You can ignore the 10k resistor and you have lost a factor of 10-3 (time const is 4.7 ms) but, yes, that's the quick answer, a little more than 4.7ms.
Jony130
Joined Feb 17, 2009
5,601
The charge formula when there is no initial voltage (Vc=0 at t=0) looks like this:
Vc=Vcc*(1-e^(-t/RC))
Solve for time we get this
t = RC•ln(Vcc/(Vcc - Vc))
t = 47kΩ*100μF•ln(12V/(12V - 8.1V)) = 47kΩ*100μF•ln(3.07) = 47kΩ*100μF * 1.12 = 5.2s
