Capacitor c to have power factor equal to .707
led23
Joined Mar 10, 2009
6
for the attachement i am trying to determine
1. the value of c to have a power factor equal to .707
2. for this value of capacitance, determine the real power transferred to the 10 K ohm load
3. what is the apparent power demanded from the source
t_n_k
Joined Mar 6, 2009
5,455
Not much interest in this problem it seems.
I have ...
1. C = 39.79 nF
2. Power = 10 mW
3. Apparent Power = 14.14 mVar
t_n_k
Joined Mar 6, 2009
5,455
what is the formula you used to come to c= 39.79 nF? if I may ask
To achieve a power factor of 0.707 (cos 45°) would require the capacitive reactance to equal the load resistance. If you are not sure why this is the case, draw a load (or power) triangle representing the resistive and reactive terms.
The required capacitive reactance magnitude is then known from the problem statement as
|Xc| = Rload = 10k
Given |Xc| you should be able to then calculate C at 400Hz.
