Hi all,
may I ask you a question please?
I am building a large circuit on breadboards, with lots of IC's. And I am wondering what is the best way to decouple each IC from the power supply ?
I have added one 100nF capacitor per IC, but the way I attached these capacitors is as follows, each capacitor has one leg as close as possible to Vdd of each IC, however the other leg is far away from the GND of the IC's. That's because I am putting the capacitors directly at the power rails from rail to rail.
Does this work? Also i have thought of adding one extra capacitor per IC, connected the same way as above but close to the GND of each IC rather than Vdd.
Should the capacitors be connected in a different way? Should them be with one leg at Vdd and the other at GND directly? Like above the IC. This makes the legs rather long which is of concern,,,
Please help...
Thank you !
Please help...
Thank you !
