Capacitance Box
SgtWookie
Joined Jul 17, 2007
22,230
Well, ya know... if you used 100 Ohm 10W wirewound resistors, you'd cut down the wear & tear on the switches, and the caps would be discharged within a couple seconds. Since the wirewound resistors have some inductance, that would help to reduce the initial current through them.
Wendy
Joined Mar 24, 2008
23,806
I already have the parts, some I no longer need. Want a string of 8 lamps that can connect to 110VAC? I have 3. :D
I was designing for extreme conditions that this sucker will likely never see. At the moment I have a 12.6VAC 400ma transformer, and with luck a 3A 12.6VAC transformer in a couple of days.
When I get this well and truly finished I'll be posting it on the complete projects forum. Maybe I'll save some physics lab some trouble.
Wendy
Joined Mar 24, 2008
23,806
Thinking about that I've come up with a solution. A schottky diode across the inputs to prevent backwards connections.
I'll draw a schematic and post it in a few days.
