Can't get past "verify you are human" with firefox
Dave Lowther
Joined Sep 8, 2016
348
I've been using the forum every day for years. I always use the latest version of firefox on windows 10.
This morning, for the first time, I get this prompt
I tick the box and it seems to consider whether I'm human for a few seconds and then puts up the same prompt again. There's no error message.
I tried with MSEdge and it works fine.
Are other firefox users seeing this?
bertus
Joined Apr 5, 2008
23,005
Do you use a vpn?
I have seen this when i use vpn.
When i go to an other vpn server the verification is gone.
Bertus
Dave Lowther
Joined Sep 8, 2016
348
Do you use a vpn?
Thank you for your reply. I don't use a vpn.
I've just realised one thing that I changed yesterday was my ad blocker. I was using ad block plus, now I'm using uBlock origin. I've tried turning it off, but that didn't fix the problem. I'll investigate this some more later today.
Dave Lowther
Joined Sep 8, 2016
348
Uninstalling the ad blocker didn't fix it. Using a private window works fine. Telling firefox to forget all cached info for the site didn't work.
Ah well, it remains a mystery for now. I can use Edge or a private window in firefox, so it's just a mild annoyance
narkeleptk
Joined Mar 11, 2019
599
Clean out all your cookies and history.
sagor
Joined Mar 10, 2019
1,055
I had a similar problem about a month ago, some sites stopped working properly. I ended up doing a "Refresh Firefox" procedure. Rather drastic (resets firefox), but it did save my bookmarks and saved logins. That did fix the issue. I had removed all add-ons before hand, cleared all cookies, history, etc. and none of that worked to clear the problem. Only the Refresh did the trick. In all the years I've used firefox, that was the first time I had to do such a refresh.
