Can your spur off a power source with a transformer?
Chefslot
Joined Sep 24, 2018
39
My idea was to add a socket to the case of the welder for a grinder power source (I will not be using both together), it is an old AC transformer welder. Everything appears fine but when I tested for continuity just to be safe when the transformer switch is thrown on it creates "short" on my live and neutral terminals in my socket (I have continuity between both) Is this normal? Added diagram
dendad
Joined Feb 20, 2016
4,642
It is ok to add a socket on the mains side for your grinder. But if you are not sure of how to do it, get some help from a qualified person.
I've added in line sockets to a couple of power drills to save running extra leads. This allows me to have a couple of drills at work. One a drill and another a power screwdriver.
As for the continuity, the resistance of a welder primary winding will be quite low. So, is your "short" 0R or just a couple of ohms?
