MaxHeadRoom
- Joined Jul 18, 2013
- 30,888
That shows a ECM/BLDC motor fitted with a 3ph rectifier to drive a DC motor but would not work BLDC to BLDC.
You can however use two stepper motors as syncro's. Transmitter - receiver.
Max.
BLDC generator to BLDC motor is Plain-Jane 3-phase power. The trapezoidal back EMF of your typical BLDC motor will be smoothed by motor inductance into a more sinusoidal shapeThat shows a ECM/BLDC motor fitted with a 3ph rectifier to drive a DC motor but would not work BLDC to BLDC.
Max.
If using two similar three coil motors, yes, the power would be AC, but that is actually what the direct connection needs to turn the second motor. I am, of course, talking about two motors with NO electronics, so that they can work like an alternator feeding a synchronous motor. That is the whole point I was trying to make.Keeping in mind that the generated power will be AC sinusoidal.
Also the commutation will be absent on ECM & BLDC motors.
Max.
Using a double beam 'scope, I have aligned my share of BLDC hall effect sensors over many decades, and the encoder equivalent on servo motors when implementing CNC retro fits, the typical BLDC motor generates 3 phase when back driven, but if you use either a 3ph or BLDC signal to drive one with another, commutation is needed.BLDC generator to BLDC motor is Plain-Jane 3-phase power. The trapezoidal back EMF of your typical BLDC motor will be smoothed by motor inductance into a more sinusoidal shape
I was refering to either a typical BLDC or Synchronous PM 3ph AC servo motor, both need commutation.If using two similar three coil motors, yes, the power would be AC, but that is actually what the direct connection needs to turn the second motor. I am, of course, talking about two motors with NO electronics, so that they can work like an alternator feeding a synchronous motor. That is the whole point I was trying to make.
Sinusoidal Commutation comes from the 3-phase generator (BLDC motor used as a generator) in the form of rotating magnetic fields shifted by 120 degrees. I respect your experience but I also design hardware and write motor drive software that actually generates the needed wave-forms for AC servo and BLDC motors using controllers and H-bridges. Hall sensors, BEMF, FOC , Space Vector are all methods of efficient (conversion of the DC supply power into AC motor power signals), precise (control of torque, speed, position) operation of motors that are needed for most accurate applications but I can guarantee that back to back 3-phase works to rotate the motor just like it does with a 3-phase induction motor.Using a double beam 'scope, I have aligned my share of BLDC hall effect sensors over many decades, and the encoder equivalent on servo motors when implementing CNC retro fits, the typical BLDC motor generates 3 phase when back driven, but if you use either a 3ph or BLDC signal to drive one with another, commutation is needed.
BTW, the output of a back driven BLDC motor is 3phase output, the AC synchronous motors are just about identical, the difference is in the commutation.
Max.
I made a similar demo of a clear plastic tube, copper tube and strong magnet for my kids science class years ago. They were pretty amazed at the fall time difference.To the OP .... A demonstration I used to do for science class was with a copper tube slightly larger than a stack of rare earth magnets. The magnets in my case were about the diameter of a pennie. I also used pennies glued together to approximate the weight of the magnets.
The Demonstration Materials: Two copper tubes (or sheet - see Note below) , Magnets, and Pennies
Demonstration:
First drop the Magnet and Pennies from the same height to show that both objects will land on the ground at the same time
Next drop the Magnet and Pennies through the copper tubes at the same time and have the students guess which one will
win the race. Even make a smaller version of the stacked pennies as well as a larger version.
The magnets will always lose because as you drop the magnet(s) it will induce a charge in the copper tube (big coil) in a way that produces a counter magnetic field in opposition to the falling magnet(s). This creates resistance that will slow down the falling magnets.
Note: You can also do this experiment on a sheet of copper or aluminum at an incline and have the magnets and pennies slide down the sheet.
Resistance yes, but not against the falling magnet, but resistance in the copper tube.This creates resistance that will slow down the falling magnets.
In the video in post #9 I demonstrated and explained how the gear reduction (actually gear induction) caused the motor to spin significantly higher RPM's of the motor. The gear ratio of that device in the video is a total of [edit] 1 to 36 [end edit], meaning the motor spun 36 times faster than the thumb wheel. And all that to simply light up one LED or the other, depending on which way it was spun. It took that much gear induction just to light up a simple LED. Spinning one motor from another (similar) is going to be very very difficult. An experimenter might have to hook up a lanyard to the shaft of one motor and pull the hell out of it to get the second motor to show visible signs of movement.it does need to turn fairly fast
For the vast majority of tests and typical experiments, and if on a budget, there is the double beam storage 'scope from such as Here .Many folks lack a dual beam scope, and I would never ever send one of mine to a school for a demonstration.
That sounds like the small cheap 3phase generator off ebay.The demonstration with the two motors was NOT done with those very poor generators that come with the $2 LED lights.
