Can we use engine starter as a DC generator ?
Forum Algérie
Joined Oct 1, 2016
15
Hello everyone,
I'm controlling the speed of an induction motor, but i don't have a brake. So, i'm wondering if i can use the engine starter of a vehicle as a DC generator ? if it's possible, i'll be using it as a brake where i connect the output to a rheostat.
I hope you got the idea.
Thanks in advance for your answers.
Kermit2
Joined Feb 5, 2010
4,162
I'm finding figures of 2500 upto 8000 RPM.
Depends on the motor and number of teeth on the flywheel ring gear.
Google has the answer if you have the info on the car the starter comes from. Like 160 teeth ring gear and 7 tooth starter gear for example.
MaxHeadRoom
Joined Jul 18, 2013
30,662
Only if it one of the current P.M. type, the older series field, NO.
What type of induction motor? 3ph or 1ph? Many 1ph do not control well.
Have you looked into DC injection braking into the AC motor?
Max.
Forum Algérie
Joined Oct 1, 2016
15
Yes, but the starter motor will likely be intended for lower speed than the induction motor and it might not like it.
yea that's another problem also.... probably we should attach the starter shaft to a big gear and the induction motor shaft to a much smaller gear. I guess this would help.
Forum Algérie
Joined Oct 1, 2016
15
Max.
it's a 3ph motor.
i know the braking by DC voltage injection, but what i intend to do here is to use starter as a load torque to see if the controller can track the speed reference.
Forum Algérie
Joined Oct 1, 2016
15
Max.
I guess it's possible to use the older series field, you know the principle of series wound generator, it's a self excited DC generator.
wayneh
Joined Sep 9, 2010
18,104
You would be time and money ahead to either use a basic hydraulic pump with a control valve and radiator or a repurposed automotive brake assembly as your load brake device.
I'd also consider an automotive alternator. They can take quite a bit of rpm. You can attach a pretty big load – a 100A load is not an unusual spec – and vary the field current to get whatever lesser load you need.
WBahn
Joined Mar 31, 2012
32,848
I'd also be concerned about the life expectancy of a starter used for this purpose. Starters are designed to be used for a few seconds a few times a day. Also, I don't know how well they would like loads much greater than they are normally called to handle and, given the high gearing, that may not be all that much. I know that when I changed the compression in my Bronco from 6.7:1 to 10:1 I started eating up starters, so much so that I made sure to carry an extra starter in the back at all times so that I could change it out when it failed.
GopherT
Joined Nov 23, 2012
8,009
Was the starter the only weak link when you did that? 6.7 to 10.0 is a 50% increase in compression (head pressure). Something had to fail earlier than expected.
shortbus
Joined Sep 30, 2009
10,050
yea, exactly.
If this is just a "one off" (a single use to find if the motor is strong enough for your project) the fastest and cheapest idea would be a Prony Brake. The next would be tcmtech's idea. https://en.wikipedia.org/wiki/Prony_brake
More ideas for one here, hard to chose one for you since we don't know your capabilities or the availability of materials. But a prony brake has been used for a long time successfully to do what you want.
https://www.google.com/search?q=prony+brake&ie=utf-8&oe=utf-8
Forum Algérie
Joined Oct 1, 2016
15
So you're saying, i can use a car alternator to load an induction motor by feeding a rheostat with the DC voltage ( from the output of the diode bridge connected to the alternator).
Forum Algérie
Joined Oct 1, 2016
15
That then goes back to #4.
DC injection for braking a AC motor.
Max.
it's not the same thing, braking by DC injection means that we feed two windings of the indcution motor by a DC voltage directly. But, what i was talking about is coupling the induction motor shaft to the one of the alternator, and the output of the alternator feeds a variable resistive load.
