Can we charge Li-Ion battery with lead acid charger
Vindhyachal Takniki
Joined Nov 3, 2014
598
1. I have a lead acid charger of 48V/20A , I can set its voltage to 54.6V to charge a li-ion battery of 13 cells in series with slightly less currnt than 20A.
2. Can we charge the li -ion battery with the lead acid charger?
What could be downfall of this?
Dodgydave
Joined Jun 22, 2012
11,395
Short answer NO, unless you want to make it explode,. Lithium-ion cells need to be monitored for current sensing for a safe charge, then disconnected.
Rahulk70
Joined Dec 16, 2016
538
Just like the other members have mentioned above, do not do it. You will blow up the battery for good. Also Li-ion cells are the least forgiving. Use the the right charger for this battery chemistry.
