You're right. I did say my name was Helplessnewbie.I thought a "Metre" was a unit of length, not a voltage....
Hi, I did as you said and tested a battery that I tested with a simpler meter but nothing happens. If anything, the meter moves a tad to the left!You plug the negative wire into the COM. - DC.+Ω terminal, and the positive into the 6V terminal.
You say that the needle went left.
It looks like the common is +DC.
Try this:
A load for the battery can be a simple 100 ohms resistor. Put that across the two terminals and measure voltage. Measure voltage without the resistor and then determine if the voltage under load is much different that without the load. If the voltage changes by more than 15% or so, it is dead. That is for typical AA batteries. If you are testing little button cell batteries for watches or hearing aids, use a 4700 or 10k resistor. Test on a new battery to get the feeling of how it should respond.Wow that is one beautiful antique! One think everyone missed. You should have a load when testing batteries. A dead battery could read the battery level with no load. You really would be better off with a cheap battery tester.
Yep but a battery tester is a lot easier.A load for the battery can be a simple 100 ohms resistor. Put that across the two terminals and measure voltage. Measure voltage without the resistor and then determine if the voltage under load is much different that without the load. If the voltage changes by more than 15% or so, it is dead. That is for typical AA batteries. If you are testing little button cell batteries for watches or hearing aids, use a 4700 or 10k resistor.
And you had the nerve to accuse me of not being able to read...One think everyone missed. You should have a load when testing batteries.
Yes, I got a cheap batter tester for Christmas. That's when Mom showed me this old meter that my uncle used to have and she was wondering if I wanted it. It's still in terrific shape and comes in its own leather case!!Wow that is one beautiful antique! One think everyone missed. You should have a load when testing batteries. A dead battery could read the battery level with no load. You really would be better off with a cheap battery tester.
Thanks for your response!!A load for the battery can be a simple 100 ohms resistor. Put that across the two terminals and measure voltage. Measure voltage without the resistor and then determine if the voltage under load is much different that without the load. If the voltage changes by more than 15% or so, it is dead. That is for typical AA batteries. If you are testing little button cell batteries for watches or hearing aids, use a 4700 or 10k resistor. Test on a new battery to get the feeling of how it should respond.
Also, your meter is not going to show a big difference since you have a 6-volt scale. You might want to buy a nice digital meter - available for $5 and up. The seemingly crappy $5 (sometimes free with coupon) meter from harbor freight will be better than the one you have.
by Jeff Child
