Can Someone help with this?
WBahn
Joined Mar 31, 2012
33,111
I1=8.4A
I2=104.1A
Okay. So how did you get the 8.4 A? (8.33 A is a better answer, but you're close enough)
Did it, perchance, involve the KVA rating and the input voltage?
Since it is an IDEAL transformer, what is the KVA at the output relative to the input?
If you know the KVA at the output and the current, can you work out the voltage?
Or, another way, if the turns ratio steps up the current, what does it do to the voltage?
