Can someone help me solving the circuit attached?
i_nour
Joined Nov 9, 2015
31
I found that the sum of the branched currents is bigger than the primary current..why? how to solve it?
Jony130
Joined Feb 17, 2009
5,488
Because in this case only one of the two diodes can conduct, and your job is to find out which one it is (based on circuit analysis).
i_nour
Joined Nov 9, 2015
31
The positive terminal of the first battery is connected to the anode while the positive terminal of the second battery is connected to the cathode and because the batteries are equivalent, they canceled out each other. Is it right?
