Can someone explain this resistor placement for me ?
Hextejas
Joined Sep 29, 2017
187
It is on a schematic that i tried to marry with another and the V- resistor gave me grief. I crudely redrew the circuit moving the resistor from V- to V+. Will they both work the same ? I guess that I am used to seeing the V resistor on the + leg.
dl324
Joined Mar 30, 2015
18,413
Images positioned for easier comparison:
You can't just swap the power supply connections.
What is the device with MFG terminals? I don't recognize it.
Whoever drew the original schematic took the effort to draw straight lines, but couldn't use the same (or at least similar) resistor symbol. and they forgot to put the arrow on the emitter of the transistor. Mind boggling...
Hextejas
Joined Sep 29, 2017
187
It's from a buzzer data sheet sep 1172
dl324
Joined Mar 30, 2015
18,413
In this case, -V is ground and +V is 3-28V. Other supply values are possible because the only requirement is that the difference between +V and -V be 3-28V.
AnalogKid
Joined Aug 1, 2013
12,184
It is a bare piezo sounder element. You can move the resistor, but you cannot swap the +V and -V connections. That is, -V connects directly to G, and +V connects to the resistor, which connects to M et al.
ak
