Can someone answer my dual power supply compatibility question please?
kubeek
Joined Sep 20, 2005
5,796
You can use it with a split supply, like any other opamp it doesn´t know the difference. What you need to do is to make sure that your inputs are within 0.5V to Vdd-0.8V (relative to pin GND), and know that the output will only swing from 0.25V to Vdd minus roughly 0.8V.
botey
Joined Oct 4, 2016
35
Thank you for your response! I also appreciate the extra info you provided.
