panic mode
- Joined Oct 10, 2011
- 5,407
this is the the top view (with PCB "see through").
green traces are on the bottom (far side) of the board.
red trace or your jumper is on the top side (closer side) of the PCB.
i guess you were missing two vias. they did not
maybe 3D view without solder-mask and PCB helps see things better. if this is manufactured as single layer PCB, top side pads and through hole plating will not be there.
