You know which microcontroller it is ?Welcome to AAC!
Someone might take pity on you if you provided well focused pictures of both sides of the board.
Why do you want the schematic? It's unlikely that you can repair or copy because all of the smarts are in the 8 pin DIP which is probably a microcontroller.
Just knowing the micro will probably be of no help as the code that was programmed into it will be unavailable.You know which microcontroller it is ?
You would have to do what anyone else would do, is revere-engineer the circuit by tracing out the printed circuit.This is an 8 function led strip light adapter and i want yhe circuit diagram of it can some one please help me out.
Can't tell from the picture. There are dozens that come in an 8 pin package.You know which microcontroller it is ?
With the rest of the circuit reverse-engineered, and the general function of the unit, it could be figured out what micro would do the job.You know which microcontroller it is ?
What's the desired end result? Reverse engineering that device is probably not be the easiest path to the solution. I've bought 8-function LED strings for next to nothing in after-Christmas sales, if you're just looking for a replacement.... i want yhe circuit diagram of it...
What are the eight functions?This is an 8 function led strip light adapter
by Mike Falter
by Aaron Carman
by Lisa Boneta.
by Robert Keim
