You still have not explained exactly where you connected the capacitor. Is it decoupling the power supply? Is it connected across the data bus?Did you connect the capacitor to anything?
The LIN Bus is connected to the transceiver through the connector pin, and the capacitor is populated for ESD protection close to pin on PCB. I am on the test to check if the LIN transceiver's internal ESD protection and ESD protection capacitor are enough without any additional ESD component.
by Aaron Carman
by Aaron Carman
by Lisa Boneta.
by Aaron Carman
