Can I run an AC stove on DC?
snote
Joined Jan 25, 2019
17
I have a power source, 4x 34V solar pannels, =136V DC!
I want to use the power to drive an electric stove.
I have a one burner stove, it needs 110V AC.
My question. Is it safe, to use it on DC? If not, what have I
to change to make it work?
Sven
BR-549
Joined Sep 22, 2013
4,928
It should.....if you have the current. One could test it with 10 car batteries in series. Or what ever voltage you want.
Solar Mike
Joined Apr 26, 2018
34
Wouldn't advise it, the AC rated thermostat contacts will self destruct first time they open. HV DC + current = high power arc just like a DC welder.
You would have to use some sort of H-Bridge circuit to square wave alternate the polarity from the DC panels to prevent arcing.
Cheers
Mike
SLK001
Joined Nov 29, 2011
1,549
The stove will most likely operate, but your solar panel probably can't supply the current you need. Your element is probably in the range of 1500 watts.
But we're all guessing, because you HAVEN'T PROVIDED THE INFORMATION WE NEED!
mvas
Joined Jun 19, 2017
539
If not, what have I to change to make it work?
Sven
What is the Model #, URL Link and Wattage of each Solar Panel ?
What is the Model #, URL Link and Wattage of the Electric Stove Burner ?
Is the Stove rated AC / DC on the nameplate ?
You need to match the Volts, and exceed the Amps, because actual PV Watts output will be much lower than you expect.
You should point the Solar Panels directly towards the sun: morning (east), then noon (up) , then evening (west).
Guaranteed to work ...
PV + Charger + Deep Cycle Battery Pack + ( MSW or PSW ) Inverter = power available all day, and dinner after sunset.
snote
Joined Jan 25, 2019
17
Right. I forgot the termostats...
Wattage is not an issue. I got 1000w and the stove is 700w.
So, I had to eliminate all circuitery and connect it with a switch directly to the panels.
Any ideas to rebuild a small and easy termostat on DC?
mvas
Joined Jun 19, 2017
539
The On/Off Switch ...
a) must be rated at 15 DC Amps or more
b) must be rated at 150 DC Volts or more - What is your max Voltage Open Circuit?
The Switch must be DC rated, not just AC rated.
Now you know why we prefer to switch AC power, not DC power.
With DC Volts, consider a MOSFET.
ian field
Joined Oct 27, 2012
6,536
Sven
Mains is usually stated as the RMS value which would give you the same heating effect as DC into a purely resistive heating element.
There may be other gadgets that don't like DC - fan and/or timer motors are likely to be synchronous type and will present the lower Dc resistance of the winding wire instead of inductive reactance of the solenoid winding, and could burn out.
Any electronics has the potential for a step down mains transformer - will probably also indicate its distress with smoke signals.
snote
Joined Jan 25, 2019
17
Einhell1024.jpg Einhellinnen024.jpg I found a switch: 250V 720A heavy duty :)
No brand of stove, just a chap chinese one. No motors etc. just heating element, the termostator and two bulbs.
I found an old car battery starter charger. Perhaps I could use some parts of this...
