Can I revise W/L ratio at LTSPICE?
Oppaya
Joined Apr 16, 2021
8
Hi, I'm trying to make spice simulation.
I have used PSPICE Lite edition, and I got to use this Lspice because of the limit of the PSPICE
(It has number limit to use component)
And I am trying to revise W or L size in LTspice, But it is hard to find it.
Can I adjust W or L size at the LTspice?
Papabravo
Joined Feb 24, 2006
22,115
What you have on your diagram is a default part. You can check the LTspice help file for the values of the default parameters. Next if you can find a part that is similar to the one you want, you can import that model into your schematic, and from there you can modify any of the device parameters.
Oppaya
Joined Apr 16, 2021
8
I know that I can change model parameter in PSPICE.
But I wonder if I can revise it one by one.
ex) M3 : W=5, L=0.1 , M4 : W=10, L=0.1
How can I do that?
