can i modify a power supply
35,299
Find out how much current is required for the LEDs and then build a constant current supply from the 19VDC output for that amount of current.
35,299
I don't know how much current you need but let us suppose you need 2A.
Then you have to dissipate (19V - 12V) x 2 A = 14W
A hunking big 3.5Ω 25W resistor will do the job - or a 6V 25W light bulb.
It would be better to find a 12VDC power supply which should not be too difficult a task.
Arcamax
Joined May 5, 2015
36
well there is the chart of the leds: i bought 2 quantities of white 1m non-waterproof
will dc work? Someone told me to use Ac power supply.(i can get some dc adapters at be@electronics where i live, the max current one i can get is 1.6Amps though)
http://www.be-electronics.com/category_s/2380.htm
http://www.be-electronics.com/product_p/rpr1201a6p5.htm
