And the rest of the equipment... at the other end of the cable?
I will have a controlled environment. Can those ESD simulators still be picked up nowadays?Right, now it makes sense. What you have is an old-style air discharge gun. The Lemo connector is plugged into an ESD simulator which generates a specific pulsed voltage, typically 7kV and a few 100uS wide pulse (simulates the ESD of someone discharging themselves) and the gun is brought close to the equipment under tested (EUT) until a spark discharges the 'gun' into/across/near the EUT and its effects noted. This is done under controlled conditions on a special table (for small devices) which acts as a ground plane.
This is normally done by, and at, specialist ESD test houses.
A modern ESD tester incorporates that in a hand-held device
Not sure what your expectations/plans are...
Thank you as wellI will have a controlled environment. Can those ESD simulators still be picked up nowadays?
You can rent or buy, but you need specialist advice. Don't know where you are.... so can't suggest anyone, but an organisation like these guys can helpI will have a controlled environment. Can those ESD simulators still be picked up nowadays?
