I've spent hours trying to find out what this component is and have come up empty handed. If someone could help me out it would be greatly appreciated!
Mod: enhanced your image.EHello thereYou have been a member longer then I. For shame you should know better.
Can you take a wider photo in order to see the other components it is connected to. The type of equipment it was taken from. Make Model number,Year, serial number all the information you have on the mystery component please!
Thank you for your help! How did you find that site above? I have tried to search so many different ways! That is the unit that plugs in to the 12 pin JST connector on the board in question. I think it was out in the weather for quite awhile, the damage seemed worse before I cleaned it.Hello there again!
it looks like an in-house component proprietary!
This is for different model but the components are the same I think you have a lot of water scale on there,it's been weathered or soda popped!
It's a clean board but no markings on the mystery component in question. sorry kiddo!
https://sites.google.com/site/mychron3/mychron3-dash-tear-down
I use a web development tool called PHP my personal research Bot it's not totally legal semantics really I use my powers for good not evil I'll leave it at that! And you are very welcome my friend.Thank you for your help! How did you find that site above?
I think you hit the nail on the head! The two outer pads are series connected V+9-15V in on a known good component like it and the center pad is ground. Having trouble finding any product for sale like it thou. After @Delta prime help and yours I have a much greater understanding of what I'm looking at! Thank YouLooks like a TBU protector at firs glance but to know what is connected to it or voltage readings would help.
Low probability of damage on your bench.So I managed to get the unit powered up and working by just jumping out the pads. What harm do you guys think I could potentially do with it wired like that? It's powered by 6 AAA batteries in series.
Can you recommend a component to put in it's place for some layer of protection?Low probability of damage on your bench.
How much current flows in that circuit?Can you recommend a component to put in it's place for some layer of protection?
Nothing, filter components basically prevent EMI spreading out/in.So I managed to get the unit powered up and working by just jumping out the pads. What harm do you guys think I could potentially do with it wired like that? It's powered by 6 AAA batteries in series.
by Aaron Carman
by Duane Benson
by Dale Wilson
by Jake Hertz
