Can anyone identify purpose of this device?
BobTPH
Joined Jun 5, 2013
11,677
And I think you will find two RF oscillators and a mixer in the shielded box inside.
If it is a scan device, they went to a lot of trouble to make such a high quality build.
Standisher
Joined Jan 16, 2015
154
After seeing your last post, that confirms it for me. Its a metal detector missing the probe head.
I think you are right! After seeing your post I made some really crude coils from stiff wire (only about 15 turns each) and stuffed them into the probe signal BNCs next to each other. Low and behold, when I approached the two coils (no touching) with a screwdriver, there was output and deflection of the dial. When I withdrew the screwdriver to about 6 inches away, output stopped. I repeated this basic & crude experiment with various metal objects and achieved the same result.
Standisher
Joined Jan 16, 2015
154
Exactly what I thought . A lot of effort seems to have put into it and it makes me believe it was a high end industrial tool.
shortbus
Joined Sep 30, 2009
10,049
One that hasn't been mentioned. It could be a Higgs-Boson detector. Don't be too fast to say no. Divinity has to do with God, and the Higgs-boson is also called the "God Particle". ;) :cool: :p
ThePanMan
Joined Mar 13, 2020
953
I would say it is consistent with a metal detector.
My vote is for a metal detector
It does seem to be a metal detector.
If a metal detector, it could have RX & TX coils?
Hence the two probe/coil inputs.
I'M SO CONFUSED!
MikeA
Joined Jan 20, 2013
455
It has a zero knob though. Maybe diviner in the sense of division? Keeping track (centering?) of something between some two objects, hence two inputs?
SamR
Joined Mar 19, 2019
5,542
I'm pretty sure it is a high-end "scientific" dowser (water finder). Apparently in some countries it is still allowable to advertise such "scientific" services to unsuspecting and gullible people and not be arrested for it. Seems India has a few such as Scientific Water Diviner.
Ya’akov
Joined Jan 27, 2019
10,360
Dousing for metals is a thing, so it could be a metal detector being marketed as something special.
The passive/active selector might indicate some sort of deep detection.
Standisher
Joined Jan 16, 2015
154
Just to throw the cat amongst the pigeons :D This is a picture of the device in it's case. The cut-outs in the foam seem to indicate that the probes may have been cylindrical and of about 2" diameter. There also seems to be space for a battery charger? I should have thought of posting this image in my OP.incase.JPG
boostbuck
Joined Oct 5, 2017
1,067
I suggest possibly a water-leak detector. There are various methods for finding leaks in high-pressure buried pipes, involving remote sensing. The closest I have been is to watch a specialist use one on my property, so I'm no expert.
BobTPH
Joined Jun 5, 2013
11,677
I find it hard to believe it is something other than a metal detector when it clearly works as a metal detector even when random coils replaced the probe that it is designed to work with.
And, once again, a scam device would be unlikely to be built with that kind of quality, unless it was being sold to the military for $10000. Why go to the trouble of making a working device if you were trying to sell something that had no chance f working?
Standisher
Joined Jan 16, 2015
154
I was being facetious. Seems everyone was cued in on a metal detector. But admittedly, the argument is not yet over.;
Does your machine have a model number? Or perhaps a name plate?
No, there is unfortunately no model number as such. The plate on the back simply repeats what is on the front i.e "Model: Deviner" and, other than the serial number I quoted above, there is no further information. I'll let this roll on a bit in case someone who has used one or was employed by the company who made it comes forward. Currently I'm expecting it to remain a mystery (although I'm inclined to believe it is a detector of metal or water .... most likely the former) :cool:
