How to write a MARIE program to calculate some basic statistics on a list of positive numbers. The program will ask users to input the numbers one by one. Assume that all numbers will be in the range 1 to 1000. To terminate the data entry, the user will input any negative number. Once the data entry is complete, the program will show four statistics about the list of numbers:
(i) Count, (ii) Minimum value, and (iii) Sum of the numbers.
As an example, if the user enters the following decimal numbers as input (one after the other)
23, 6, 78, 36, 3, 250, 127, 210, -5
the program would output the following values as the count, minimum and sum respectively:
8
3
733
Assume that the user will always provide valid numbers as input, that is, do not worry about dealing with invalid input data.
Write comments within your program so that a reader can understand it easily.
8
3
733
