Can anybody help with this circuit??
AlbertHall
Joined Jun 4, 2014
12,637
I suspect that no-one will be able to help without information on the component shown as as X in a circle (light bulb? but what voltage/wattage)
spinnaker
Joined Oct 29, 2009
7,830
And a better photo rather than a shadow of your finger stuck in your ear. ;)
Do you have a scanner? I would suggest scanning the sheet and posting the png file.
You also might want to try a schematic drawing program like Diptrace. Diptrace can be very easy to use. You would want to print to pdf to post.
Sebastián Gómez 1
Joined Dec 5, 2016
6
the x is a bulb.... but you can suppose that it doesn't exist, it is the charge in the circuit, but it doesn't change a lot in the next of the schematic
and no, i don't have scanner
