Can any frequency expert please explain this mess ?
Ksortzi
Joined May 26, 2019
19
The origional photos I posted was from spectrum analyzer and this was the settings those photos were on.
Thats what led me to the pop the question in this forum initial. But like I said I am no means a professional so what I'm looking at should be incurred by one that is correct im your advise
Perhaps the noise is not electrical in nature. Do you use propane or natural gas for heating purposes?
Gas
Ksortzi
Joined May 26, 2019
19
I live out in the boonies but few miles away is a main transfer. Research and suits out east is what lead me to checking gas to begin with because of the high pressure gas transfer in the distribution lines. I've done a far amount of research into this theory and the "hum" but..... they wouldn't admitt to it even if that was the case.
Deleted member 115935
Joined Dec 31, 1969
Interesting
I once knew a person that lived out in the middle of no where,
and they swore they had a hum noise every now and then.
I never heard it ,
but interestingly , when the military establishment a few miles down the road closed, the noise disappeared.
and effect does not justify a cause, but it was interesting .
If you suspect its coming from a given place, can you take measurements nearer ? it should be present and louder ?
( might be a battery inverter needed, and do a measurement at home and around home using it to compare )
Also, 21 Khz, a parabolic reflector on the microphone should be of use to locate where the strongest point is.
https://www.wildtronics.com/parabolic.html#.YAVv_eigKUk
may be you could make something similar ?
Ksortzi
Joined May 26, 2019
19
Trust me I have not ruled out the ones who think that the 2% are always expendable for the greater good. You won't get an admitting from them. Closest amature radio is like 2 miles, im surrounded by corn and forest, town is like 2 miles. I mean like the shit is clearly as day in the audio. All diffrent days all in dead silent rooms and a few out side the garage door. 2 I think I took.vi have so many more. Idk keeps saying upload does not have allowed extention. I dont know what format they are in id have to look
Ksortzi
Joined May 26, 2019
19
Mp4 so apparently I can't up load mp4s either. Fml I'm sure if I could get the audio up here one of you noble educated guys would know im sure.
BobTPH
Joined Jun 5, 2013
11,592
I’m sorry, but this sounds like a medical issue to me. I would suggest that you see a hearing specialist to investigate it.
Bob
wayneh
Joined Sep 9, 2010
18,129
You could try zipping it. I think the server here allows zip files? Or maybe just change the extension to .txt and make it clear in your post that the extension is fake.
Ksortzi
Joined May 26, 2019
19
@BobTPH
How can this be medical as the OP is saying they have recordings of the noise.
Exactly. I went to the doctor. Paper work says my hearing is perfect. Above average. So trust me this issue i do feel is beyond my home. Im starting to see millions of other people all over the world with the same issue hearing the same exact thing. That is mathmaically and scientifically impossible.
Ksortzi
Joined May 26, 2019
19
The more I dig into it the more I see very identical sittiations. Ruling out every thing in my home from a scientific stand point would give me confirmation and clairity.
Ksortzi
Joined May 26, 2019
19
Brcause the recording is typical of what you would see with no input, random noise.
Bob
The problem is its not random noise. It has clock work timing. 5amish, 8amish noonish 6pmish, 9pmish midnight is. So on and so forth with audio and its meta data to defent the timing.
Ksortzi
Joined May 26, 2019
19
I'm going to down load a file converter and see if I can get the audio up here it won't let me up load mp4. I can't find any info on here what exceptible file formats are for this forum though. I've never had an issue uploading on here so this is my first time encounter with regards to the extension issue
wayneh
Joined Sep 9, 2010
18,129
Did you see my earlier comment? Here's an .mp4 disguised as text
BobTPH
Joined Jun 5, 2013
11,592
Seriously? That is quite a claim. Can
you present some evidence of that? How, for example, can you know they are hearing exactly the same thing?
Bob
