Can a old-fashioned Germanium Diode be used with a 555 to drive a 4017, or drive a 4017 alone??
Kim Sleep
Joined Nov 6, 2014
396
I was able to do it once before, and now, no matter what can not do it again.
What I got before was a nice, really slow, rather "random" triggering of the 4017.
But now, I can no longer seem o do it, and Ive backed myself into a corner, as Im supposed to recreate it again.
Thanks for any help you may have.
I have now attached the schematic. Diode used is an Oa7
34,719
I assume that you are trying to build a random noise generator.
There are random noise circuits using reversed biased PN junction devices. You will have to amplify the signal to make it trigger logic circuits.
34,719
What does it take for a signal to drive a CMOS logic circuit?
Not much. All you need is the signal to exceed the lower and upper switching threshold voltages.
For CMOS gates, the threshold is just below and above Vdd/2.
Dodgydave
Joined Jun 22, 2012
11,395
Yes, but i would also put a 100 ohms resistor in series with the diode as well , because when the chip discharges the capacitor the voltage across it may blow the diode.
AnalogKid
Joined Aug 1, 2013
12,094
Looking at #13, it looks like the C2 charging current is the approx. 1.3 uA. This is a reasonable leakage current value for a germanium diode. I have one old datasheet that lists the 1N34 reverse current as "30 uA @ 10 V". Does it vary enough with temperature, etc. to be a source of randomness? Don't know, but probably not.
To the TS - what is it you are trying to achieve?
What is the goal for the overall circuit?
Do you think you need a random-frequency clock source?
If so, why?
ak
eetech00
Joined Jun 8, 2013
4,705
The 4017 has restrictions on the characteristics of the clock signal. The signal must meet these restrictions to reliably trigger the 4017. Basically, the signal needs to be as "square" as possible with sharp edges. The 555 in your diagram conditions the randomized signal so it can reliable trigger the 4017 in a somewhat random fashion.
