Can a Meggar type meter be used as a HI-Pot tester?
MaxHeadRoom
Joined Jul 18, 2013
30,772
Yes, the high voltage version, that model goes to 2500v.
There are two versions of a Megger, one measures insulation, such as the one referenced, the other is low voltage, for measuring very low resistance.
Max.
Dynaman
Joined Jan 17, 2008
94
Thanks Max. Yes I ordered the unit. I want to do a "Voltage Withstand test" @ 1.5kv. Primary windings to chassis ground. I think this unit will do it. Whatever the resistance is, I'll simply calculate the current, and that should be my leakage current.
Aram:)
