Camera Remote Operator
MaxHeadRoom
Joined Jul 18, 2013
30,662
No idea what The freq, will have to check, but only $6.00 off ebay 4 channel..
Should be easy to modify for solid state output.
Max.
AnalogKid
Joined Aug 1, 2013
12,134
What is the camera model number? It might help to have a visual of what you are working with in terms of button locations, etc.
ak
LesJones
Joined Jan 8, 2017
4,511
Hi Max,
Have you considered using a cheap camera such as this rather than an expensive camera. I bought one similar to the one in the link to photograph a hedgehog that feeds in our garden. It produces quite good pictures and video and it looks easy to get to the push button switches to trigger it electrically. As it is it is not suitable for my purpose as it does not work with infra red. I have found some information about removing the infra red filter but I have not yet tried doing this.
Les.
jpanhalt
Joined Jan 18, 2008
11,087
What sort of range to you need? I suspect something of eBay with relays may be similar to a garage door opener. That is, very limited range.
KL7AJ
Joined Nov 4, 2008
2,229
Hi Max,
Les.
As good as modern low-cost digital cameras are, Mr. Headroom is going to need a good zoom/telephoto lens. There is no real substitute (yet).
MaxHeadRoom
Joined Jul 18, 2013
30,662
The S602 has digital zoom.
I think I have something that will work using a 12vdc solenoid coil.
Just have to fabricate the operator.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,662
Thanks, but I looked at the pic controlled RC servo, but it was a little overkill, basically what the guy is doing in post#12, I only need two positions, in that case, the 555 was a better/simpler choice than a Pic.
But I am working on a simple solenoid operated version, I have all the pieces I think I need, so at the moment it is a work in progress, if it works out, I will post the results.
Max.
camerart
Joined Feb 25, 2013
3,830
Max.
Hi M,
If you find that a solenoid is a bit abrupt, and you can tolerate wires between you and the camera, then a modified servo may be better, where the servo is used as a simple geared motor. (You'll have to take some of the mechanics out of the servo)
Good luck,
C.
MaxHeadRoom
Joined Jul 18, 2013
30,662
The solenoid is from a liquid valve and for the armature I am using a 8mm headless shoulder bolt which has about a 6mm to 7mm travel, so it seems ideal as it is completely silent, and I don't think the abrupt operation will be a difficulty, hopefully.
It is cushioned with a soft return spring.
Max.
