Calculating resistance
Hextejas
Joined Sep 29, 2017
187
This is the circuit that I am building ( again ). I am doing these over and over until I can predict and measure them correctly.fig2.33.JPG
The lamp that I used was this.
5v, .06 amps, incandescent. Everything works fine and I get these numbers measured at the lamp.
Voltage drop = 5.25
Current = 61ma
So, using ohms law, 61 = 5.25 / x
Which in my calculator is 86ohms.
My problem is that when I measure the resistance of the bulb I get 12.5 ohms.
Why ? Or am i expecting things to be too exact.
Thanks,
George
bertus has the major effect. Measurement to one ohm accurately is not necessarily difficult, but it's an effect. The test leads may have a resistance of close to an ohm.
philba
Joined Aug 17, 2017
959
Yeah, incandescent bulbs do that. You do need to factor in the cold current to make sure it doesn't exceed the components in your circuit
WBahn
Joined Mar 31, 2012
32,829
This is the circuit that I am building ( again ). I am doing these over and over until I can predict and measure them correctly.View attachment 140608
Voltage drop = 5.25
Current = 61ma
Thanks,
George
I think this was pointed out in your other thread -- the resistance of an incandescent bulb filament is a STRONG function of temperature -- at full operating temperature (i.e., literally white hot) they are typically 13 to 14 times the resistance at room temperature.
neonstrobe
Joined May 15, 2009
200
You have to be careful measuring the resistance of lamps at room temperature because the current you pass into the lamp might actually heat it. Keeping the voltage low is therefore important: the best way to measure it is to pass a small current and measure the voltage across it.
You can estimate the temperature of a lamp from its resistance, using tungsten resistance data. Many lamps are rated at 2700K and these show a 13:1 typical change while torch bulbs may run at only 2200K and show a 10:1 change.
