Your 9V battery got warm because the circuit is drawing too much current.
At 6V output the battery energy is practically exhausted.
A typical PP3 9V battery has a capacity of about 500mAh and is designed for low power applications such as smoke detectors. Typically, it can supply 50mA for 10 hours. Drawing more than 50mA is anyone's guess as to how long it should last.
Amplifiers are classified into different classes, A, B, C, D, E etc.
Class-A amplifiers are power hogs but are the most linear.
Class-B push-pull amplifiers are more power efficient because only one transistor of the output pair is conducting. It suffers from severe cross-over distortion when one transistor takes over from the other.
Class-AB amplifier is a compromise between class-A and class-B. If you bias the output stage towards class-A you reduce cross-over distortion but draw more current at idle.
If you bias the output stage towards class-B you reduce the current drawn but you have to settle for more cross-over distortion.
Your 9V battery is going dead fast because your DC bias is more towards class-A.
Adjust your DC bias towards class-B and live with a little bit more cross-over distortion.
A PP3 9V battery is not an appropriate power source for a high power audio amplifier.
