Bypass capacitor leads don't reach. Add a wire or a second capacitor?
bignobody
Joined Jan 21, 2020
97
Sorry if this seems like a silly question but I am curious about how other people deal with this.
I've started experimenting with some ICs with a larger number of pins (14-16) and often the Voltage In and Ground pins that I want to put a 0.1uf bypass capacitor across are too far apart for the leads to reach.
Should I solder a wire to the capacitor leads so they reach, or can I get the same result by adding a second capacitor and having one just before the IC Voltage In and the second just after the Ground pin?
Thanks for reading!
35,179
Depends.
If you are doing a PCB layout, you would run the power rails such that your capacitor leads will fit nicely.
For DIP logic ICs, I run signal traces on the top side and Vcc and GND on the bottom side, running parallel in between the left and right rows of IC pins.
If you are building a DIY hobby project on perfboard, then you do what you have to do.
Use through hole ceramic capacitors with long leads and install the cap with the shortest leads to Vcc and GND pins of the IC you want to decouple.
