Buzzing power strip
electronewb
Joined Apr 24, 2012
260
I can hear a major buzz coming from a power strip that I have even with no load on it. What could be wrong with it and should I bother fixing it or just toss it out and buy a new one? And also is there any hazard to use that power strip?
RichardO
Joined May 4, 2013
2,270
It sounds real dangerous to me. I would pitch it.
But first, I would open it up to see what is going on. :)
(I am guessing that a couple of the contacts are lightly touching.)
18,148
Is this anything more than a power strip? I mean, surge suppressor, circuit breaker, etc.? A picture might help.
But yeah, I wouldn't use it until it was fixed. And I wouldn't fix it unless you feel comfortable doing that.
Don't do anything while it's plugged in.
GopherT
Joined Nov 23, 2012
8,009
It likely has a small SMPS inside to run the LED and any additional gadget. Something seems to be failing if it is loud. If it is just barely audible, it could just be a resonance with the mounting frame that is vibrating. The magnetic field can cause the metal around the SMPS to vibrate in the audible range.
