buying a chassis power supply
38,822
That is a dual ± output supply.
They appear to share a com (ground) terminal with plus and minus output terminals.
The S terminals are likely for remote sense of load voltage to eliminate the voltage drop of the output wire resistance from the load current.
There are two pots (below) to adjust their respective output voltage.
Not clear what the AC input voltage or output DC voltage is.
LV-456_42
Joined Dec 21, 2024
45
ahh i see so COM is GND , , yes its not very clear what voltage this one gives when i google the board part number it seems to range what voltages this style of board would produce from 12v to 5v, i suspected at first the com pin it was a communication pin for somthing external,
BobTPH
Joined Jun 5, 2013
11,654
I must be missing something. Is there is anything in that ad specifying the voltage and current capacity? If not, why would you buy it?
AnalogKid
Joined Aug 1, 2013
12,278
Nothing on the board is smart enough to have a communications protocol. COM definitely is the common GND for the bipolar outputs. There are no mounting holes, so the original assembly might have used the TO-3 device mounting to secure the board.
ak
LV-456_42
Joined Dec 21, 2024
45
No i don't think so i did mention that when i google the part number of the board, it seems to have a range of 12v or 5v, this board is in alot of different power supplies from what i can tell its from a brand called "power one".
Tonyr1084
Joined Sep 24, 2015
9,744
Funny, to me, you called this a "Vintage" PS board. It was built the 41st week of 1994. Look at the bottom of the screen capture and you see 4194.
To me, THIS is a "Vintage" power supply:
https://www.ebay.com/itm/235681458941
No PCB (Printed Circuit Board), all point to point wiring. No chips. Not even Tubes. Just a few transformers and capacitors. Can't tell if there are any diodes. I'd imagine there must be if it's a DC supply. The one you call "vintage" is a DC supply. Nevertheless - - - .
