Bulb Replacement Guide
prerakk
Joined May 21, 2015
28
hi friends,
hope you are doing good !
so friends I have this handheld light from lightforce brand , Blitz halogen , which bulb stop working .it was supppose be use with car for long distance focus light probably for night hunt.and its specs are as follow :
  • 12V 100 watt Xenophot® 2000 hour bulb (24V halogen version available)
  • Lightweight polycarbonate, glass filled nylon composite construction
  • Gore® Protective Vent (IP57/67/68/IP69K) to protect against moisture/contaminant ingress
guys the brand is not local in my country and I am not able to contact them due to some reasons. and while trying to find it online through local seller websites . i been getting different options. also I am confuse if I buy replacement bulb it will work in it or not
this is original website for product :
https://www.lightforce.com/AUS/sl-series-halogen-handheld-1
this is the replacement product I can find :
- Philips 12V 100W 7023 Gy6.35 Low Voltage Halogen
kindly suggest me any alternative replacement that can work same.
thanks in advance
prerakk
Joined May 21, 2015
28
