Building a power supply for a Bunsen burner?
PartyLine4
Joined Jan 12, 2013
27
I thought it would be neat to try and build a power supply for a fireboy plus Bunsen burner.
The burner calls for 14Vac and draws an alleged .4A
I am a complete noob when it comes to these types of circuits, so any help is appreciated.
18,164
The specs claim the mains adapter outputs 9VDC, 0.5A. That doesn't match your comment. You obviously need to know which it is.
What part of this do you want to "build" versus buy? Whether you need 14VAC or 9VDC, you can buy off-the-shelf much cheaper than you could build your own.
You should also determine whether the stock adapter is a simple, old fashioned wall wart (unregulated, transformer) or a SMPS, which likely supplies a regulated voltage.
BillO
Joined Nov 24, 2008
1,001
The older model of the Fireboy used a 14VAC adapter rated at 7VA. This would just simply be a 14 volt output transformer. Seeing as it it unregulated AC, this implies internal rectification, filtering and regulation. Hence you might find anything from 13V to 15V would do fine. Something like a Hammond Manufacturing 166G14 would be ideal for the purposes.
