Being new to the forum please let me know if this is the correct place to setup this thread.
I’ve been researching how to build a LED moth trap and come up with using the LEDs below to replicate a mercury lamp spectrum. I’ve learned a fair bit after reading a number the threads here and I’ve come up with running 8x3watt LEDs in series made up of :
Colour No Vf (V) If (mA)
UV 4off 3.9-4.5 700. See ebay, data sheet not available
Daylight 1 3.2-4.0 750. See Futureeden for the rest, data sheet available
Warm, Blue 2 3.4-4.0 750
Royal Blue 1 3.4-4.0 750
Violet 1 3.5-4.5 750
And using a step up/down boost buck voltage converter, See Ebay. Chose this after working out the input supply voltage i.e. Vin = Vo + (Vf x LEDn) and supply wattage = Vf x total LED current, running all at 3.5v giving about 350mA. I aim to use portable Li-ion R25 battery's to run the LEDs for an hour to start.
I'm assuming that the If of a given LED will be exceeded some where between the minimum and maximum Vf, yes? And if so would I be better running a supply voltage for less than 3.2V?
Will this setup work or have I miss understood the theory?
